*scale_thickness
Scales the thickness of an entity.
*scale_thickness entity_type mark_id string_array number_of_strings
HyperMesh Tcl Modify Command
This command scales the thickness and sets the scaled thickness back to entity. This functionality is currently supported only in the Radioss and LS-DYNA user profiles.
- entity_type
 - The type of entity to scale. Currently only supported for elems.
 - mark_id
 - The ID of the mark that contains the entities to scale. Valid values are 1 and 2.
 - string_array
 - The ID of the string array that contains the array of input parameters. The string array is created using the *createstringarray command. This should always be set to 1.
 - number_of_strings
 - Integer indicating the size (number of strings) in the string array created using *createstringarray.
Examples
Add 2 to the existing thickness of all elements in the model, with a minimum thickness of 10 and a maximum thickness of 20:
*createstringarray 3 "add : 2" "MinThickness : 10" "MaxThickness : 20"
*createmark elems 1 all
*scale_thickness elems 1 1 3
      Multiply element 15-17 thicknesses by 0.5:
*createstringarray 1 "multiply: 0.5"
*createmark elems 1 15-17
*scale_thickness elems 1 1 1
      Subtract 2 from the thickness of all elements:
*createstringarray 1 "add: -2"
*createmark elems 2 all
*scale_thickness elems 2 1 1
   # Handle error
}Version History
13.0
