*surfacecreatedraglinealongvector
Create surface(s) by extruding line(s) along a vector.
*surfacecreatedraglinealongvector mark_id vector distance options comp_mode
HyperMesh Tcl Modify Command
This command creates surface(s) by dragging line(s) along a vector. If the distance is negative, the opposite direction to vector is used for dragging.
mark_id
The mark ID containing the lines that you wish to drag.
vector
Temporary vector ID defining the direction of the drag.
distance
The length of the drag. Negative values indicate opposite direction to the vector.
options
0 - Do not merge input lines. A surface is created for each input line.
1 - Merge input lines into smooth lines when possible. A surface is created for each group that forms tangentially continuous line.
comp_mode
Parameter specifying how entities are organized into components:
0 - Surfaces are created in the current component.
1 - Surfaces are created in the same component as the selected lines. The result is not predictable if the lines are originally in different components.
To create 3 surfaces by dragging the input lines 35, 27 and 29 along the x-axis 5 units, creating the surfaces in the current component:
*createmark lines 1 35 27 29
*createvector 1 1.0 0.0 0.0
*surfacecreatedraglinealongvector 1 1 5.0 0 0
   # Handle error
Version History
10.0
