*blmesh_2d
Generates a 2D boundary layer mesh on surfaces/elements.
*blmesh_2d base_entity_type base_mark_id bl_entity_type bl_mark_id num_layers first_layer_thickness growth_rate string_array number_of_strings
HyperMesh Tcl Modify Command
- base_entity_type
 - The type of entities to use for the base. Valid values are surfs and elems.
 - base_mark_id
 - The ID of the mark containing the base entities. Valid values are 1 and 2.
 - bl_entity_type
 - The type of entities to use for the boundary layers. Valid values depend on the base entity type:
 - bl_mark_id
 - The ID of the mark containing the boundary layer entities. Valid values are 1 and 2.
 - num_layers
 - The number of boundary layers to generate.
 - first_layer_thickness
 - The thickness value of the first layer.
 - growth_rate
 - The growth rate of the boundary layers.
 - string_array
 - The ID of the string array that contains the additional input parameters. The string array is created using the *createstringarray command. This should always be set to 1. Valid parameters include:
 - number_of_strings
 - Integer indicating the size (number of strings) in the string array created using *createstringarray.
Examples
*createstringarray 2 "element_size: 2.0" "element_type: quads"
*createmark surfs 1 10
*createmark lines 1 20 21 25 26 37 38
*blmesh_2d surfs 1 lines 1 5 0.15 1.2 1 2Errors
   # Handle error
}Version History
11.0
