*morphremoveconstraint
Remove constraint(s).
*morphremoveconstraint nodetype marknode option
HyperMesh Tcl Modify Command
- nodetype
 - Nodes or morphconstraints
 - marknode
 - Node or morphconstraint mark number.
 - option
 - 0 - Remove nodes on mark from morph constraints.
*morphremoveconstraint (NODES,1,1)
      If option is 0, any constraints on the nodes on the mark are removed.
None.
