Creates a connector from a mark and assigns a
    connectorcontrol/connectorcontroldefault.
        *CE_ConnectorCreateByMarkWithCC
        entity_type mark_id ce_style num_links link_entity_type link_mark_id string_array
          number_of_strings cc_type cc_name
        HyperMesh Tcl Modify Command
      Creates a connector from a mark and assigns a connectorcontrol/connectorcontroldefault.
          - entity_type
          - The entity type that specifies the location to create connectors. Valid values
            are:
          - elems (for area)
          - lines (for spot, bolt, seam and area)
          - nodes (for spot, bolt and apply_mass)
          - points (for spot, bolt and apply_mass)
          - surfs (for area).
          - mark_id
          - The ID of the mark containing the entities.  Valid values are 1 and 2.
          - ce_style
          - The style of connectors to create. Valid values are apply_mass, area, bolt, seam, and
            spot.
          - num_links
          - The number of links to use.
          - link_entity_type
          - The type of entity to create links for. Valid values are:
          - comps (for spot, bolt, seam, area or apply_mass)
          - elems (for spot or apply_mass)
          - nodes (for spot or apply_mass)
          - surfs (for spot, seam or area)
          - tags (for spot or apply_mass)
          - link_mark_id
          - The ID of the mark of link entities.  Valid values are 1 and 2.
          - string_array
          - The string array ID that contains the additional input parameters. The string array is
            created using the *createstringarray command. This should always be
            set to 1.
          - Strings are indicated using the format "name=value". Valid strings are:
                - area_mesh_size=<value>
                - The mesh size for area connectors when entity_type is surfs.
                  Default 10.0.
                - area_mesh_type=<value>
                - The mesh type for area connectors when entity_type is
                  surfs.
                - 0 - Trias
                - 1 - Quads
                - 2 - Mixed
                - 3 - Right trias
                - area_offset=<value>
                - Offset area connectors created from node or line lists from the selected
                  location by this value. Default 0.0.
                - area_width=<value>
                - Width of area connectors created from node or line lists. Default 1.0.
                - line_density=<value>
                - The density for spot or seam connectors on lines. Default 0.0.
                - line_offset=<value>
                - Offset value from the ends of the line for spot or seam connectors on lines.
                  Default 0.0.
                - line_offset_flag=<value>
                - 0 - Do not offset connectors (default)
                - 1 - Offset connectors
                - line_spacing=<value>
                - The spacing for spot or seam connectors on lines.  Default 1.0.
                - link_elems_geom=<value>
                - Specifies whether to connect elems (default) or geom.
                - link_rule=<value>
                - Specifies the link rule. Valid values are now, at_fe_realize or none
                  (default).
                - relink_rule=<value>
                - Specifies the relink rule. Valid values are id, name or none (default).
                - seam_area_group=<value>
                - Flag for seam or area connector grouping:
                - 0 - No (default)
                - 1 - Yes
                - tol=<value>
                - Add entities as links only within this distance of the specified location.
                  Default 0.0.
                - tol_flag=<value>
                - 0 - Do not use tol (default)
                - 1 - Use tol
          - number_of_strings
          - Integer indicating the size (number of strings) in the string array created using
              *createstringarray.
          - cc_type
          - The type of control to assign.  Valid values are connectorcontrol and
          - cc_name
          - The name of the connectorcontrol/connectorcontroldefault to assign.
    Examples
      Create a spot connector at the location of node 10 to connect component 3 and 4 using a
        tolerance of 6.0 and assign connectorcontrol
        my_acm:
*createmark nodes 1 10
*createmark components 2 3 4
*createstringarray 5 "link_elems_geom=elems" "link_rule=now" "relink_rule=none" "tol_flag=1" "tol=6.000000"
*CE_ConnectorCreateByMarkWithCC nodes 1 "spot" 2 comps 2 1 5 connectorcontrol "my_acm"
      Incorrect usage results in a
Tcl error. To detect
        errors, you can use the
catch
        command:
   # Handle error
