*elementtestorthogonality
Tests 3D elements for whether or not they pass the orthogonality element quality check, and puts those that fail on the specified outputmark.
*elementtestorthogonality entity_type input_mark_id orthogonality output_mark_id dimension contour title
HyperMesh Tcl Modify Command
- entity_type
 - The entity types to be checked. Currently, elements is the only allowable option.
 - input_mark_id
 - The mark that contains the elements to test.
 - orthogonality
 - The value to use as a threshold beyond which elements should be considered to have failed the test.
 - output_mark_id
 - The mark where HyperMesh should put the elements that fail the test.
 - dimension
 - A code telling to measure the dimension of:
- 4 - Measure 3D elements.
 - contour
 - A code telling if HyperMesh should:
- 0 - Display the results of the test normally.
 - 1 - Display the elements color coded by their ratings.
 - 2 - Build a histogram showing the distribution of ratings.
 - title
 - The title to label the curve in the histogram.
Examples
To test all displayed 3D elements for an orthogonality value less than 0.2:
*createmark elements 1 "displayed"
*createmark elements 2
*elementtestorthogonality elements 1 0.2 2 4 0 "3D Orthogonality")
   # Handle error
}Version History
2019
