*markintersection
Determines the intersection between two marks and stores the results in the first mark.
*markintersection entity_typeA mark_idA entity_typeB mark_idB
HyperMesh Tcl Modify Command
This command determines the intersection between the entity IDs that exist on mark_idA on those on mark_idB. The results are then placed on mark_idA.
Both entity_typeA and entity_typeB must be the same.
To delete the intersection between the elements on marks 1 and 2:
*createmark elems 1 1 2 3 4
*createmark elems 2 4 5 6 7
*markintersection elems 1 elems 2
*deletemark elems 1
This will delete element 4.
   # Handle error
