*unrealizeengineeringentities
Unrealize engineering entities.
*unrealizeengineeringentities entity_type mark_id unrealize_mode
HyperMesh Tcl Modify Command
Unealize engineering entities.
entity_type
The type of engineering entities to unrealize.
mark_id
The ID of the mark containing the engineering entities to unrealize. Valid values are 1 and 2.
unrealize_mode
0 - Delete entities from realization. Only current solver/profile is affected.
1 - Maintain entities from realization. Only current solver/profile is affected.
10 - Delete entities from realization. All entities including other solvers/profiles are affected.
11 - Maintain entities from realization. All entities including other solvers/profiles are affected.
Unrealize masses with IDs 10 and 20:
*createmark masses 1 10 20
*unrealizeengineeringentities masses 1 0
   # Handle error
Version History
2017.2
