*blockwallfindintersect
Intersects one- and two-dimensional finite elements with cells in a finite difference block.
*blockwallfindintersect blockname wallname entity type mark
HyperMesh Tcl Modify Command
blockname
The name of the block.
wallname
The name of the wall into which cells are to be inserted.
entity type
The type of entity in the mark (either elements or components).
mark
The ID of the mark.
