*midsurface_remove_target
Finds the surface vertex that is closest to a chosen point and, if it is close enough, removes targets from this vertex.
*midsurface_remove_target face offsetpoint_x offsetpoint_y offsetpoint_z point_sel_code
HyperMesh Tcl Modify Command
- face
 - The index of the surface to offset.
 - offsetpoint_x
 - The X coordinate of a point near the desired vertex.
 - offsetpoint_y
 - The Y coordinate of a point near the desired vertex.
 - offsetpoint_z
 - The Z coordinate of a point near the desired vertex.
 - point_sel_code
 - This argument is not currently used (0).
You cannot manually employ this command, because HyperMesh must internally generate the index values (they cannot simply be typed in).
None.
