*curvemathexternalfilter
Runs an external filter on a curve.
*curvemathexternalfilter outputcurve xbased filter parameter
HyperMesh Tcl Modify Command
outputcurve
The name of the curve to be generated.
xbased
1 - If the function should operate on the x coordinate.
0 - If the function should operate on the y coordinate.
filter
The name of the filter.
parameter
The user-defined parameters for the filter.
