*elementtestvolumeareaskew
Tests 2D and 3D elements using the volumetric and areal element quality check.
HyperMesh Tcl Modify Command
Tests 2D and 3D elements using the volumetric and areal element quality check. The 3D volumetric skew corresponds directly to the Abaqus and Fluent CFD tetra element quality checks.
- entity_type
 - The entity types to be checked. Only elements are supported.
 - mark_id
 - The mark ID containing the elements to test. Valid values are 1 and 2.
 - skew
 - The value to use as a threshold beyond which elements should be considered to have failed the test.
 - dimension
 - A code to measure the dimension of:
- 2 - Measure 2D elements.
 - 4 - Measure 3D elements.
 - output_mark_id
 - The mark ID where the failed elements will be placed. Valid values are 1 and 2.
 - contour
 - A flag that determines how the results are presented. Valid values are:
- 0 - Display the results of the test normally.
 - 1 - Display the elements color coded by their ratings.
 - 2 - Build a histogram showing the distribution of ratings.
 - title
 - The title to label the curve in the histogram. Only required, if contour is 2.
*createmark elems 1 "displayed"
*elementtestvolumeareaskew elems 1 0.6 0 4 0 ""*createmark elems 1 "displayed"
*elementtestvolumeareaskew elems 1 0.5 0 2 0 ""Errors
   # Handle error
