*sketchedit
Edits the sketch entity by adding/removing/modifying entities with various operations.
*sketchedit <select_type>=<selection> operation=<value> ?<option1>=<value1>? ?<option2>=<value2>? ... ?<optionN>=<valueN>?
HyperMesh Tcl Modify Command
- <select_type>=<selection>
 - The entity or entities that are to be queried. There are several ways to provide the
            entities to be queried. Only one option can be used at a time:
- id=<sketch_id>
 - The ID of the sketch entity.
 - name=<sketch_name>
 - The name of the sketch entity.
 - operation=<value>
 - The operation to perform. Valid values are:
- add - Add the new entities into the sketch.
 - modify - Modify the existing entity data in the sketch.
 - remove - Remove the entity/entities from the sketch.
 - split - Split the entity into multiple entities.
 - fillet - Add the fillet to the corner points.
 - offset - Offset entities by offsetting chain with offset distance.
 - mirror - Mirror entities.
 - clone - Copy/cut entities and paste them in the same or a different sketch.
 - <option>=<value>
 - The method and its settings used for the operation.
Examples
*sketchedit id=1 operation=add entitytype=circle creationmethod=circle_center_radius centerposition={0.0 0.0} radius=2.0000Errors
   # Handle error
}Version History
2021.2
