*elementqualitymodifyhole
Modifies holes in a mesh using radial, angular and circumferential adjustment methods.
*elementqualitymodifyhole node_index move_option x y z string_array number_of_strings
HyperMesh Tcl Modify Command
This command modifies holes in a mesh using radial, angular and circumferential adjustment methods. If washers are linked with the hole, then the hole and washers move together. If they are not linked, the hole and washers move independently. The surrounding elements are also re-meshed based on the number of layer specified.
This command only functions between an *elementqualitysetup command and an *elementqualityshutdown command. The index is purely a local value appropriate to that session of the tool, and it cannot be computed from the node ID you want to change.
- node_index
 - The index of a node on the hole/washer within the internal data structures of the interactive element cleanup and quality index edit/optimize tools.
 - move_option
 - Hole node movement.
- 1 - In radial direction.
 - 2 - In angular direction.
 - 3 - In radial and angular directions.
 - 4 - In circumferential direction.
 - x
 - x-coordinate of a target location for the selected node used for hole/washer modification.
 - y
 - y-coordinate of a target location for the selected node used for hole/washer modification.
 - z
 - z-coordinate of a target location for the selected node used for hole/washer modification.
 - string_array
 - The string array ID that contains the additional input parameters. The string array is
            created using the *createstringarray command. This should always be
            set to 1. Valid parameters include:
- InputRadius: <radius>
 - The target radius to use for hole/washer modification (Optional).
 - InputAngle: <angle>
 - The rotation angle to use for hole/washer modification (Optional).
 - InputArcLen: <length>
 - The circumferential arc length to use for hole/washer modification (Optional).
 - LinkWasher: <value>
 - 0 - Hole and washers are not linked and move independently.
 - NumRemeshLayer: <value>
 - The number of layers to be re-meshed after hole/washer modification.
 - RetainWasher: <value>
 - 0 - Do not retain the washer of nearby holes on re-meshing.
 - number_of_strings
 - Integer indicating the size (number of strings) in the string array created using *createstringarray.
*createmark elems 1 displayed
*elementqualitysetup 1
eval *createstringarray 3 "LinkWasher: 1" "NumRemeshLayer: 2"
*elementqualitymodifyhole 278 4 5.3 -8.4 0.0 1 2
*elementqualityshutdown 1Errors
   # Handle error
}Version History
11.0.130
