*organizecomponents
Reorganizes elements in existing components based on selected policy.
*organizecomponents policy ?preserve_element_include?
HyperMesh Tcl Modify Command
Reorganizes the existing elements by grouping them based on one of the following policies:
  1. By property
    Elements of same property are grouped under one component. The component is assigned that property and the component inherits the meta data such as name, color, module, include from the property
  2. By material
    Elements of same material are grouped under one component. The component inherits the meta data such as name, color, module, include from the material
  3. As one component
    All valid elements are grouped under one component.
By default, the elements follow the components to the destination include which in turn follows the targeted entity (properties or materials). The current element include organization can be preserved using the optional argument preserve_element_include.
policy
The grouping policy. Valid values are:
1 – By property
2 – By material
3 – As one component
Optional argument to preserve the current element include structure. Valid values are 0 or 1.
Examples
To organize all components by property:
*organizecomponents 1
or
*organizecomponents byprop
   # Handle error
Version History
2022
