*markersupdate
Updates multiple MBD markers.
*markersupdate mark_id node_id syst_id sys_flag color update_node update_syst update_color
HyperMesh Tcl Modify Command
This command updates MBD analysis markers.
- mark_id
 - The ID of the mark containing the markers to be updated. Valid values are 1 and 2.
 - node_id
 - The ID of the node that defines the location of the markers.
 - syst_id
 - The ID of the orientation coordinate system.
 - syst_flag
 - A flag for the coordinate system. A value of 0 indicates that the coordinate system will be blank.
 - color
 - The color of the markers.
 - update_node
 - A flag indicating if the node will be updated.
 - update_syst
 - A flag indicating if the system will be updated.
 - update_color
 - A flag indicating if the color will be updated.
To update markers m1 and m2 to both use orientation system ID 25:
*createmark sensors 1 "m1" "m2"
*markersupdate 1 0 25 1 0 0 1 0
   # Handle error
}Version History
10.0
