*hmmeshsurfacesphere
Within the automeshing module, generates quad or tria elements using a surfaceless algorithm. Can only be used with *surfacemode 3 and one of the *surfacesphere... commands.
*hmmeshsurfacesphere quads
HyperMesh Tcl Modify Command
quads
If nonzero, specifies that the created elements should be quads.
This example identifies a spherical region passing through the given four nodes, and, without actually building a surface, creates 150 elements with a density of 15 along a longitude and 10 around the equator:
*surfacemode 3
*createlist nodes 1 159 141 178 228
*surfacespherefromfournodes 1
*set_meshedgeparams 0 15.0 0 0 0 0 0 0 0
*set_meshedgeparams 1 10.0 0 0 0 0 0 0 0
*set_meshedgeparams 2 15.0 0 0 0 0 0 0 0
*set_meshedgeparams 3 10.0 0 0 0 0 0 0 0
*hmmeshsurfacesphere 1
*storemeshtodatabase 0
*ameshclearsurface
None.
