*projectmarktoplane
Projects a group of entities to a plane.
*projectmarktoplane entity type mark plane vector toplane
HyperMesh Tcl Modify Command
- entity type
 - The type of entities contained on the mark.
 - mark
 - The ID of the mark containing the entities to be projected.
 - plane
 - The ID of the plane to which the entities will be projected.
 - vector
 - The vector along which the entities will be projected.
 - toplane
 - A flag indicating if the entities should be projected to the plane or to the normal of the plane (1 for plane, 0 for normal).
To project elements 10, 11, 12, 13 to the plane with a normal of (1.0, 0.0, 0.0) based at the origin along the vector (1.0, 1.0, 1.0):
*createmark elements 1 10 11 12 13
*createplane 1 1.0 0.0 0.0 0.0 0.0 0.0
*createvector 1.0 1.0 1.0
*projectmarktoplane elements 1 1 1 1
      *createmark , *createplane , and *createvector are required.
None.
