*set_default_quality_criteria
Sets the default criteria, adjusted to a specified element size, as the current quality criteria.
*set_default_quality_criteria elementsize
HyperMesh Tcl Modify Command
elementsize
The double value of the ideal element size for the criteria to be set.
In interactive mode, this command also resets the current values in the quality index panel.
*set_default_quality_criteria(3.5)
None.
