*hwCfdCreateMeshControlsFromSolverOptions
Creates mesh control entities from the equivalent solver options entities in the CFD profile.a
*hwCfdCreateMeshControlsFromSolverOptions mesher
HyperMesh Tcl Modify Command
This command is used to create mesh control entities from the solver option entities created inside the CFD profile. These mesh controls will be used both for surface mesh as well as volume mesh.
mesher
The name of the meshing application to create the mesh controls for. Must be set to hm.
Examples
To generate mesh controls for HM from the solver options:
*hwCfdCreateMeshControlsFromSolverOptions "hm"
   # Handle error
Version History
2019
