*createentitiesfromsource
Creates entities using an external source file.
*createentitiesfromsource <option1>=<value1> <option2>=<value2> ... <optionN>=<valueN>
HyperMesh Tcl Modify Command
- entitytype=<value>
 - The type of entity to create. Currently only supported for beamsects.
 - source=<file>
 - The path and file name to the source file.
Examples
Create beam sections using a csv file:
*createentitiesfromsource entitytype=beamsects source=C:/temp/beam_section.csv
   # Handle error
}Version History
2019
