*rotatedummyrootbodytoeulerangles
Rotates a dummy about a given point.
*rotatedummyrootbodytoeulerangles name ax ay az cx cy cz
HyperMesh Tcl Modify Command
The mechanism must have the enabled flag set to true for this to be possible.
name
The name of the root body of the dummy.
ax
The desired x Euler angle of the dummy with respect to the global axes.
ay
The desired y Euler angle of the dummy with respect to the global axes.
az
The desired z Euler angle of the dummy with respect to the global axes.
cx
The x-coordinate of the center point.
cy
The y-coordinate of the center point.
cz
The z-coordinate of the center point.
To move a dummy with root body named "Pelvis Angle Gauge" to Euler angles 10, 50 and 20 about the point (0,0,0):
*rotatedummyrootbodytoeulerangles "Pelvis Angle Gauge" 10 50 20 0 0 0
   # Handle error
Version History
14.0.120
