*ossmooth_geometry
Extract the final design geometry from OptiStruct topology, topography and shape optimization results.
*ossmooth_geometry modelsel fem_filename load_op outputcode tetrameshingcode units autobead autobeadthreshold autobeadlayer isosurface surfacecode densitythreshold detectbridge lowthreshold distancecoefficient optismoothboundary lapiteration lapfeatureangle lapsmoothboundary remesh surfacereduction reductionfeatureangle createplotel
HyperMesh Tcl Modify Command
- modelsel
 - Model selection option.
- 0 - Specify model file path to read.
 - 1 - Use current model in HyperMesh.
 - fem_filename
 - The full name and path to the OptiStruct .fem results file generated from the optimization. Used only when modelsel = 1.
 - load_op
 - Execution/load option. Valid values are:
- 0 - Create .oss file only to be used in standalone version (do not execute ossmooth)
 - 1 - Do not load geom into HyperMesh.
 - 2 - Load geom into HyperMesh.
 - outputcode
 - Output file format. Valid values are:
- 1 - Nastran
 - 2 - IGES
 - 3 - STL
 - 4 - H3D
 - tetrameshingcode
 - Flag indicating whether to create tetramesh after creating isosurface (1=yes, 0=no).
 - units
 - Units to use for IGES output. Valid values are:
- 1 - inch
 - 2 - mm
 - 4 - foot
 - 6 - meter
 - 10 - cm
 - autobead
 - Flag indicating whether to create an autobead design (1=yes, 0=no).
 - autobeadthreshold
 - Threshold value for autobead (real value ≥ 0 and ≤ 1).
 - autobeadlayer
 - Layer value for autobead (integer value 1 or 2).
 - isosurface
 - Flag indicating whether to create an isosurface (1=yes, 0=no).
 - surfacecode
 -  The method to use. Valid values are:
- 0 - No smoothing, isosurface only
 - 1 - Optimization based smoothing
 - 2 - No smoothing, element threshold
 - 3 - Laplacian smoothing
 - densitythreshold
 - The density threshold for topology optimization (real value ≥ 0 and ≤ 1).
 - detectbridge
 - Flag indicating whether to detect connectivity in isosurface (1=yes, 0=no).
 - lowthreshold
 - The lower density threshold for connectivity detection (real value ≥ 0 and ≤ 1).
 - distancecoefficient
 - The distance coefficient to use in optimization based smoothing (real value ≥ -50 and ≤ 50).
 - optismoothboundary
 - Flag indicating whether to include the boundary or not in optimization based smoothing (1=yes, 0=no).
 - lapiteration
 - The number of iterations to use in Laplacian smoothing (integer ≥ 0).
 - lapfeatureangle
 - The feature angle to use in Laplacian smoothing (real value ≥ 1 and ≤ 80).
 - lapsmoothboundary
 - Flag indicating whether to include the boundary or not in Laplacian smoothing (1=yes, 0=no).
 - remesh
 - Flag indicating whether to remesh when creating an autobead design or/and isosurface (1=yes, 0=no).
 - surfacereduction
 - Flag indicating whether to use surface reduction (1=yes, 0=no).
 - reductionfeatureangle
 - The feature angle to use when requesting surface reduction (real value ≥ 1 and ≤ 80).
 - createplotel
 - Flag indicating whether to create PLOTEL elements (1=yes, 0=no).
To execute OSSmooth on the C:/test/os1.fem, C:/test/os1.grid and C:/test/os1.sh files, loading geometry back to HyperMesh, requesting Nastran output, creating 1 layer autobead with remesh design with 0.3 bead threshold, no surface reduction, 0.3 topology optimization threshold, detect connectivity in isosurface with 0.2 low threshold, Laplacian smoothing, 10 iterations, 30 degrees feature angle and include the boundary, create PLOTEL elements:
*ossmooth_geometry 0 "C:/test/os1.fem" 2 1 0 1 1 0.3 1 1 3 0.3 1 0.2 0 0 10 30 1 1 0 10 1
   # Handle error
}Version History
11.0.101
