*solidmap_solids_end
Ends a multiple-solid solidmap command block.
HyperMesh Tcl Modify Command
This command is used by the multi-solid mapping algorithm to indicate the end of a solid mapping command block. It must be paired with a *solidmap_solids_begin command.
*solidmap_solids_set_density
*solidmap_solids_set_elemsize
*solidmap_solids_set_face_params
*solidmap_solids_set_mapfaceExample
To mesh solids 32 and 41 with a default elem size of 2.0 except on edges 2 and 4 which should have an elem size of 1.0:
*createmark solids 1 32 41
*solidmap_solid_begin 1 0 2.0
*createmark lines 1 2 4
*solidmap_solids_set_elemsize 1 1.0
*solidmap_solid_end
   # Handle error
}Version History
10.0
