*baroffset
Updates the offsets in the global system for a single bar or bar3 element.
*baroffset element_id offset_x_a offset_y_a offset_z_a offset_x_b offset_y_b offset_z_b
HyperMesh Tcl Modify Command
- element_id
 - The ID of the bar or bar3 element to update.
 - offset_x_a
 - The offset in the x-direction at end a. This is defined in the global system.
 - offset_y_a
 - The offset in the y-direction at end a. This is defined in the global system.
 - offset_z_a
 - The offset in the z-direction at end a. This is defined in the global system.
 - offset_x_b
 - The offset in the x-direction at end b. This is defined in the global system.
 - offset_y_b
 - The offset in the y-direction at end b. This is defined in the global system.
 - offset_z_b
 - The offset in the z-direction at end b. This is defined in the global system.
Examples
*baroffset 23 1.0 2.0 3.0 4.0 5.0 6.0Errors
   # Handle error
