*convertcord3rtocord1r
Updates the target solver ID for beamsections.
HyperMesh Tcl Modify Command
Converts CORD3R system to CORD1R system in OptiStruct. The command gets executed internally when changing the solver interface from OptiStruct to Nastran as Nastran does not have CORD3R systems.
To convert CORD3R systems to CORD1R systems:
* convertcord3rtocord1r
   # Handle error
Version History
2022
