*createentitysameas
Create a new entity that is a clone of a source entity.
*createentitysameas entity_type entity_id ?entityname=<value>?
HyperMesh Tcl Modify Command
Create a new entity that is a clone of the original. Attributes and data names are both cloned, however, collected entities are not cloned along with collectors.
There are also a few limitations to this command:
  • Rigid wall entities are not supported.
entity_type
Entity type to use as source.
entity_id
The ID of the source entity to clone.
entityname=<value>
The name of the new entity.
Examples
To duplicate the component with ID 100:
*createentitysameas comps 100
To duplicate the component with ID 100 with the new component named “comp01”:
*createentitysameas comps 100 entityname=comp01
   # Handle error
Version History
13.0
2022 - Added optional input entityname.
