*rigidlinkwithset
Create a rigid link element with dependent nodes attached as a node set connected to the element. The attached node set may exist before or may be created from a given mark of dependent nodes while the rigid link element is created.
*rigidlinkwithset independent mark dependent_set dof
HyperMesh Tcl Modify Command
- independent
 - The independent node of the element.
 - mark
 - The ID of the mark containing the dependent nodes if the dependent nodes set is created for the rigid link element;
 - dependent_set
 - The ID of an existing nodes set being attached to the rigid link; 0 - if the rigid link and an attached nodes set are being created using a mark of dependent nodes.
 - dof
 - The degrees of freedom for which the element is active (any of the digits 1-6).
To create a rigid link element with independent node 100 and dependent nodes 101, 102, and 103 with nodes having all six degrees of freedom:
*createmark(nodes,2) 101 102 103
*rigidlinkwithset(100,2,0,123456)
      A new nodes set with an autogenerated name is created for the rigid link element, the dependent nodes 101,102,103 being placed to this nodes set.
To create a rigid link element with independent node 100 and node set 25 attached as a dependent node set, with nodes having all six degrees of freedom:
*rigidlinkwithset(100,0,25,123456)
      The *createmark() command is required to create a rigid link element with an attached independent node set.
None.
