*messagefilefilter
Sets a filter on the type of messages written when using the *messagefileset command.
*messagefilefilter type filter
HyperMesh Tcl Modify Command
type
The type of message to filter. This should match with the value set in *messagefileset. Valid values are:
FEINPUT - any messages passed to
HM by an FE-input processes. HM - all supported type values.
filter
A list consisting of the messages to filter to the file. Multiple values can be specified. The list should be enclosed in quotes. Valid values are:
ERROR - error messages
INFORMATION - information messages
WARNING - warning messages
To save all FE-input error messages to a file named C:/test.dat:
*messagefileset "feinput" "C:/test.dat"
*messagefilefilter "feinput" "error"
   # Handle error
Version History
10-SA1-120
