*equationcreate
Creates an equation between a dependent node and multiple independent nodes.
*equationcreate mark_id independent_dofs dof_size independent_weights weight_size dependent dof weight constant
HyperMesh Tcl Modify Command
This command creates an equation between a dependent node and multiple independent nodes.
mark_id
The mark ID containing the independent nodes. Valid values are 1 and 2.
independent_dofs
The array ID containing the degrees of freedom for which each respective independent node of the equation is active. This array is created with the *createarray command.
The DOFs use bit operations to represent the value. In order to specify multiple DOFs for a node, corresponding values for the required DOFs must be summed.
  • DOF1 - 1
  • DOF2 - 2
  • DOF3 - 4
  • DOF4 - 8
  • DOF5 - 16
  • DOF6 - 32
For example, there are 2 independent nodes with DOF1 and DOF3. The array of independent DOFs will be [5 5].
dof_size
The size of the independent_dofs array. This should be equal to the number of independent nodes.
independent_weights
The array ID containing the weight for each respective independent node. The size of array is 6* dof_size. This array is created with the *createdoublearray command.
For example, there are 2 independent nodes with DOF1 weights 1.2 and DOF3 weights 1.3. The array of independent weights will be [1.2 1.2 1.2 1.2 1.2 1.2 1.3 1.3 1.3 1.3 1.3 1.3].
weight_size
The size of the independent_weights array. This should be equal to 6*dof_size.
dependent
The dependent node ID.
dof
The degree of freedom for which the dependent node of the equation is active. Valid values are 1 through 6.
weight
The dependent node weight.
constant
The constant value assigned to all independent and dependent nodes.
To create an equation with dependent node 100 and independent nodes 101-103 with all independent nodes having DOF1, DOF3 and DOF4, a weight of 1.23 and a constant of 5.0, and the dependent node having DOF5:
*createmark nodes 1 101-103
*createarray 3 13 13 13
*createdoublearray 18 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23 1.23
*equationcreate 1 1 3 1 18 100 5 1.23 5.0
   # Handle error
