*segmentsetremoveelems
Removes elements from a segment set.
*segmentsetremoveelems name mark_id
HyperMesh Tcl Modify Command
Removes elements from a segment set. If all elements are removed, the empty segment set still exists.
name
The name of the segment set to update.
mark_id
The ID of the mark containing the elements to remove. Valid values are 1 and 2.
Examples
To remove elements 100 and 101 from the segment set "test":
*createmark elems 1 100 101
*segmentsetremoveelems  "test" 1
   # Handle error
Version History
2020
