*bardirectionupdate
Updates the direction node for multiple bar and/or bar3 elements.
*bardirectionupdate mark_id orientation_node y_dir
HyperMesh Tcl Modify Command
- mark_id
 - The ID of the mark containing the bar and/or bar3 elements to update. Valid values are 1 and 2.
 - orientation_node
 - The orientation node ID. y_dir specifies whether this node defines the local y- or local z-axis.
 - y_dir
 - If set to 1, then orientation_node defines the local y-axis of the bar. Otherwise, orientation_node defines the local z-axis.
Examples
*createmark elements 1 17
*bardirectionupdate 1 5 1Errors
   # Handle error
