*CE_GlobalSetInt
Set global integer parameters relating to the display of connectors.
*CE_GlobalSetInt name value
HyperMesh Tcl Modify Command
This command sets global integer parameters to control the display of connectors.
- name
 - The name of the parameter to set:
- g_ce_colorby
 - Determines the connector coloring:
- 0 - by state
 - 1 - by component
 - 2 - by layer
 - 3 - by style
 - g_ce_realizedvis
 - Turn off/on realized connectors
 - g_ce_unrealizedvis
 - Turn off/on unrealized connectors.
 - g_ce_failedvis
 - Turn off/on failed connectors.
 - g_ce_modifiedvis
 - Turn off/on modified connectors.
 - g_ce_lt2tvis
 - Turn off/on connectors with fewer than 2 layers.
 - g_ce_2tvis
 - Turn off/on connectors with 2 layers.
 - g_ce_3tvis
 - Turn off/on connectors with fewer than 3 layers.
 - g_ce_gt3tvis
 - Turn off/on connectors with 3 layers.
 - g_ce_spotvis
 - Turn off/on spot connectors.
 - g_ce_seamvis
 - Turn off/on seam connectors.
 - g_ce_areavis
 - Turn off/on area connectors.
 - g_ce_boltvis
 - Turn off/on bolt connectors.
 - g_ce_applymassvis
 - Turn off/on apply mass connectors.
 - g_skip_imprint
 - Skip the imprint run and places the imprint elements in a separate component when set to 1.
 - g_do_strict_imprint
 - Resolve conflicts during the mesh imprint when set to 1.
 - g_do_keep_snap
 - Snap to an edge or feature during mesh imprint when set to 1.
 - g_ce_boltcylinderdisplaystatus
 - Display status:
- 0 - Bold on
 - 1 - Bolt dynamic
 - 2 - Bolt off
 - g_ce_boltcylinderdisplaytransparency
 - Set the transparency for the bolt cylinder.
 - value
Examples
*CE_GlobalSetInt g_ce_colorby 1
      Version History
9.0
