*morphhandlecreatenodes
Creates handles at nodes on mark on domain.
*morphhandlecreatenodes nodetype marknode dhandletype dmarkhandle domainpointer domainptr name
HyperMesh Tcl Modify Command
- nodetype
 - Nodes
 - marknode
 - Node mark number.
 - dhandletype
 - Handles
 - dmarkhandle
 - Dependent handle mark number.
 - domainptr
 - ID of domain.
 - name
 - Name of handle(s) to be created.
*morphhandlecreatenodes (NODES,1,HANDLES,1,1,"bob")
      Handles are created on the specified domain at the nodes on the mark with dependencies on the handles on the mark. The handle mark may be empty.
The name does not need to be unique since this command will create a unique name for each new handle by adding numbers after the name.
None.
