*entitybundleaddid
Adds a single entity to a data item of a bundle.
*entitybundleaddid name data_item id
HyperMesh Tcl Modify Command
- name
 - The name of the entity bundle to be modified.
 - data_item
 - The data item of the entity bundle to be modified. Note that these indices start with 0.
 - id
 - The ID of the entity to add. Note that the entity type is inferred from the bundle definition.
To add entity ID 17 as the first data item of the bundle "compbundle":
*entitybundleaddid "compbundle" 0 17
   # Handle error
}Version History
14.0.130
