*refineelementsbydeviation
Refine elements to chordal deviation.
*refineelementsbydeviation mark deviation minlength
HyperMesh Tcl Modify Command
- mark
 - The ID of the mark which contains the elements to be refined.
 - deviation
 - The maximum chordal deviation.
 - minlength
 - The minimum element edge size.
To refine the elements to chordal deviation:
*createmark(elements,1) 86 88 113
*refineelementsbydeviation(1,0.01,0.1)
      *createmark() is required.
None.
