*separate_fillets
Detects fillets in 3D models, groups them by radius and width, and moves the fillet surfaces to separate components created for the fillet groups.
*separate_fillets entity_type input_mark_id output_mark_id string_array number_of_strings
HyperMesh Tcl Modify Command
This command takes as input a mark of surfaces or solids of a 3D body. It recognizes fillets in the 3D body and groups them by radius and width. The command creates a component with an autogenerated name for each fillet group and moves the fillet surfaces to the corresponding components.
Optionally the surfaces of the detected fillets can be put to an output mark.
- entity_type
 - The type of input entities. Valid values are surfaces or solids.
 - input_mark_id
 - The ID of the input mark. Valid values are 1 and 2.
 - output_mark_id
 - The ID of the output mark to put the surfaces of the detected holes. Valid values are 0, 1 or 2. If set to 0, no surfaces are placed on the mark.
 - string_array
 - The ID of the string array that contains the fillet width and radius group information. The string array is created using the *createstringarray command. This should always be set to 1.
 - number_of_strings
 - Integer indicating the size (number of strings) in the string array created using *createstringarray.
To separate fillets from all surfaces using the following groups:
Group 1:
min_fillet_radius - 0.001
max_fillet_radius - 10.0
min_fillet_width - 0.01
max_fillet_width - 30.0
Group 2:
min_fillet_radius - 10.0
max_fillet_radius - 20.0
min_fillet_width - 30.0
max_fillet_width - 50.0
*createmark surfaces 1 "all"
*createstringarray 2 "0.001 10 0.01 30" "10 20 30 50"
*separate_fillets surfaces 1 2 1 2
   # Handle error
}Version History
10.0
