*displaycollector
Controls the display state of a collector.
*displaycollector entity type mode name elements geome
HyperMesh Tcl Modify Command
- entity type
 - Collector types. Valid types for this function are:
- Components
 - Loadcols
 - Systcols
 - Vectorcols
 - Multibodies
 - mode
 - The mode being performed, defined by the following:
- on - All collectors are turned on.
 - all - All collectors are turned on.
 - off - All collectors are turned off.
 - none - All collectors are turned off.
 - toggle - All collectors are toggled (visible become invisible and vice-versa).
 - reverse - All collectors are toggled (visible become invisible and vice-versa).
 - name
 - The collector name to be used in the above functions. This parameter may be left blank, if function is set to all, none, or toggle.
 - elements
 - Indicates if elements within components are to be turned on or off.
- 1 - Yes
 - 0 - No
 - geometry
 - Indicates if geometry within components is to be turned on or off.
- 1 - Yes
 - 0 - No
*displaycollector(component,on,fender,1,1)
