*removetransformation
Removes transformations from positions.
*removetransformation mark_id1mark_id2
HyperMesh Tcl Modify Command
Alternatively, *setvalue can be used.
mark_id1
The ID of the mark containing the position entities to which the transformations in mark_id2 must be removed from.
mark_id2
The ID of the mark containing the transformation entities to be removed.
Examples
To remove all the transformations from all the positions:
*createmark positions 1 all
*createmark transformations 1 all
*removetransformation 1 1
Version History
2019
