*splitelementswith1D
Splits shell elements on all sides, along with all connected 1D elements.
*splitelementswith1D inferred mark_id
HyperMesh Tcl Modify Command
inferred
  • 0 - Do not use an inferred surface if no geometry exists
  • 1 - Use an inferred surface if no geometry exists
mark_id
The ID of the mark containing the elements to split. Valid values are 1 and 2.
Examples
To split elements 1-10, along with all connected 1Ds:
*createmark elems 1 1-10
*splitelementswith1D 0 1
To split elements 1-10, along with all connected 1Ds, using an inferred surface:
*splitelementswith1D 1 1
   # Handle error
