*rigidlink
Creates a rigid link element between an independent node and multiple dependent nodes.
*rigidlink independent mark dofs
HyperMesh Tcl Modify Command
- independent
 - The independent node of the element.
 - mark
 - The ID of the mark containing the dependent nodes.
 - dof
 - The degree of freedom code for which all of nodes of the element are active (any of the digits 1-`6).
To create a rigid link element with independent node 100 and dependent nodes 101, 102, and 103 with nodes having all six degrees of freedom:
*createmark(nodes,2) 101 102 103
*rigidlink(100,2,123456)
      A *createmark() command is required to define the mark.
None.
