*savefailedsurfstomark
Scans all the displayed surfaces, finds those for which all the meshing algorithms failed, and places them on the specified mark. This command is used after one of the commands performing meshing by surfaces.
*savefailedsurfstomark surfs_mark
HyperMesh Tcl Modify Command
surfs_mark
The mark the surfaces failed to be meshed must be placed to. It must be 1 or 2.
To mesh displayed surfaces and place failed surfaces on mark 2:
*createmark(surfaces,1) "displayed"
*defaultmeshsurf(1,20,2,2,1,0,1,1,1,0,0,0,0)
*createmark(surfaces,2)
*savefailedsurfstomark(2)
Note that *createmark(surfaces,2) is placed before *savefailedsurfstomark(2) to clear all the surfaces from the specified mark.
None.
