*morphmapnormaloffset
Offset elements on mark in normal direction.
*morphmapnormaloffset typeelem markelem typefix markfix sym con blend offset umark
HyperMesh Tcl Modify Command
- typeelem
 - Elems
 - markelem
 - Mark number of elements to map
 - typefix
 - Nodes
 - markfix
 - Mark number of fixed nodes
 - sym
 - 0 - Do not use symmetry (only option)
 - con
 - 0 - Do not use constraints
 - blend
 - 0 - Do no blend unselected nodes
 - offset
 - Distance to offset elements
 - umark
 - 0 - Use all elements to calculate normals
*morphmapnormaloffset (ELEMS,1,NODES,1,0,1,0,10.0,1)
      If blend is on, no fixed nodes have been selected, and no mapped nodes are a part of any domain, this command will automatically assign all non-mapped nodes as fixed nodes.
None.
