*migrateloadcolcardstoanalysisparam
Updates solver cards defined as load collectors to analysisparameters entity and removes the CAALOAD load collector card.
HyperMesh Tcl Modify Command
Updates the EIGRL, EIGRA, EIGRD, EIGC, NLPARM, NLADAPT, NLOUT, NLMON, TLOAD1, TLOAD2, RLOAD1, RLOAD2, ACSRCE, DLOAD, UNBALNC, RGYRO Cards in Load collectors to Analysisparameters entity and removes the CAALOAD Load collector card. All the reference IDs are migrated as well.
Examples
To migrate load collector cards to analysisparameters entity:
* migrateloadcolcardstoanalysisparam
  # Handle error
            Version History
2022
