*setcurrentinclude
Specifies the include file into which HyperMesh should place newly created entities.
*setcurrentinclude id shortname
HyperMesh Tcl Modify Command
- id
 - The ID of the file. If this is 0, then HyperMesh uses the shortname to find the file.
 - shortname
 - The shortname of the file, as defined when creating the include (see *createinclude() ).
If the ID is 0, and the shortname is empty (""), then HyperMesh will place newly created entities in the main output file instead of an include file.
None.
