*removesubmodel
Deletes a solversubmodel or include file, optionally removing all of its contents as well.
*removesubmodel submodel_type id shortname remove
HyperMesh Tcl Modify Command
If both id and shortname are empty, this command removes all solversubmodels and include files from the database (but does not delete the contents). If the contents are not deleted, they move to the parent include file.
- submodel_type
 - Use solversubmodel to remove a solver submodel or includefile to remove an include file.
 - id
 - The entity ID, or 0 to use shortname.
 - shortname
 - The short name of the solver submodel or include file. This can be empty if id is specified other than 0.
 - remove
 - 0 - Do nore remove the contents of the object when deleting.
Examples
To remove the solversubmodel entity with ID 10 and delete its contents:
*removesubmodel solversubmodels 10 "" 1
   # Handle error
}Version History
2019
