*AE_AttachmentControlCreateFromDefault
Creates an attachment control that can be used for attachment realizations and saved to the binary file.
*AE_AttachmentControlCreateFromDefault name default reserved
HyperMesh Tcl Modify Command
Must be called after *AE_AttachmentControlDefaultCreate.
name
The name of the new attachment control.
default
The internal control default to derive from:
rigidpatch
rigidspiler
reserved
Reserved for future use. Must be set to 1.
Examples
Create an attachment control named "myattachmentcontrol", derived from the rigid spider default:
*AE_AttachmentControlDefaultCreate "" 1
*AE_AttachmentControlCreateFromDefault "myattachmentcontrol" "rigidspider" 1
   # Handle error
Version History
2020
