*morphupdateendcondition
Updates the end condition of one or two morph volume edges.
*morphupdateendcondition n1 n2 n3 x y z mode
HyperMesh Tcl Modify Command
- n1
 - Node at end of first edge.
 - n2
 - Node between first edge and second edge.
 - n3
 - Node at end of second edge (if necessary).
 - x
 - X component of vector for end direction
 - y
 - Y component of vector for end direction
 - z
 - Z component of vector for end direction
 - mode
 - 0 - free
*morphupdateendcondition (21,22,23,1.0,0.0,0.0,1)
      This command either frees the specified edge end, sets the direction of the edge end equal to the given vector, or enforces a tangency condition between two edges. The end of an edge which is affected by this command is marked by n1.
None.
