*ME_ModulesHierarchyLibrarySync
Finds library related information for a part from a connected part library and updates Part Browser.
*ME_ModulesHierarchyLibrarySync id options
HyperMesh Tcl Modify Command
Finds library related information for a part from a connected part library. Library related information such as Major Revision, Study Revision and Library Revision are then updated in Part Browser and Property Area.
id
The ID of the module/part for which information is needed.
options
The list of input options, passed as a comma separated string enclosed in quotes. Valid options are:
libraryname=<value>
The name of the currently connected part library.
updatesignal=<value>
0 - Part Browser and Property Area refresh is not done
1 - Part Browser and Property Area refresh is done
Update library related information for part 100 using library MyLibrary and updated Part Browser and Property Area:
*ME_ModulesHierarchyLibrarySync 100 "updatesignal=1, libraryname=MyLibrary";
   # Handle error
Version History
2019.1
