*segmentsetcreateusingfacenumber
Creates a segment set using 2D element edges or 2D/3D element faces.
*segmentsetcreateusingfacenumber name color mark_id face_number reverse_normals element_id option
HyperMesh Tcl Modify Command
name
The name of the segment set to create.
color
The color of the segment set. Valid values are 1-64.
mark_id
The ID of the mark containing the elements to use. Valid values are 1 and 2.
face_number
The face number of the element (starting from 0).
reverse_normals
Create segment set:
0 - Along element normal
1 - Opposite element normal
element_id
If non-zero, specifies the single element to use instead of mark_id. option must be set non-zero.
option
If non-zero, specifies to use element_id instead of mark_id.
Examples
To create a segment set named "test" with elements 1-100 using face number 3:
*createmark elems 1 1-100
*segmentsetcreateusingfacenumber "test" 5 1 3 0
   # Handle error
Version History
2020
